Zum Hauptinhalt wechseln
Black and Decker TO1303SB Heat Controls Replacement
Was du brauchst
  1. Black and Decker TO1303SB Heat Controls Replacement, Top Cover: Schritt 1, Bild 1 von 2 Black and Decker TO1303SB Heat Controls Replacement, Top Cover: Schritt 1, Bild 2 von 2
    • Remove the six 9.5mm screws on the back panel using a #2 Phillips screwdriver.
  2. Black and Decker TO1303SB Heat Controls Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 13mm screws, located between the feet on the bottom of the cover, using a Torx T15 screw driver.
  3. Black and Decker TO1303SB Heat Controls Replacement: Schritt 3, Bild 1 von 1
    • Using the metal spudger, carefully pry out the rubber base on each foot to access the screws.
  4. Black and Decker TO1303SB Heat Controls Replacement: Schritt 4, Bild 1 von 1
    • Remove the 11.5 mm screws using a #2 Phillips screwdriver.
  5. Black and Decker TO1303SB Heat Controls Replacement: Schritt 5, Bild 1 von 2 Black and Decker TO1303SB Heat Controls Replacement: Schritt 5, Bild 2 von 2
    • Remove the back cover by gently pulling the sides of the cover apart from the rest of the oven. Then, tilt the cover towards the face and pull back at an upward angle. The cover should slide right off.
  6. Black and Decker TO1303SB Heat Controls Replacement, Control Knobs: Schritt 6, Bild 1 von 1
    • Using two metal spudgers, pry the top control knob directly outward.
  7. Black and Decker TO1303SB Heat Controls Replacement: Schritt 7, Bild 1 von 1
    • Using the two metal spudgers, pry the middle control knob directly outward.
  8. Black and Decker TO1303SB Heat Controls Replacement: Schritt 8, Bild 1 von 1
    • Using the two metal spudgers, pry the bottom control knob directly outward.
  9. Black and Decker TO1303SB Heat Controls Replacement, Heat Controls: Schritt 9, Bild 1 von 1
    • Remove the two 5.5mm screws, that are holding the oven controls to the face, using a #2 Phillips head screwdriver.
  10. Black and Decker TO1303SB Heat Controls Replacement: Schritt 10, Bild 1 von 1
    • Remove the two 7.5mm screws, that hold the toaster controls to the face, using a #2 Phillips head screwdriver.
  11. Black and Decker TO1303SB Heat Controls Replacement: Schritt 11, Bild 1 von 1
    • Remove the two 5.5 mm screws, that hold the timer to the face, using a #2 Phillips head screwdriver.
    • The timer is removed so that the wires that need to be un-clipped from the heat controls are easier to access.
  12. Black and Decker TO1303SB Heat Controls Replacement: Schritt 12, Bild 1 von 2 Black and Decker TO1303SB Heat Controls Replacement: Schritt 12, Bild 2 von 2
    • Press down the metal tab on the oven heat control connector using needle nose pliers and pull outwards to remove the connector.
  13. Black and Decker TO1303SB Heat Controls Replacement: Schritt 13, Bild 1 von 1
    • Using your thumb, carefully peel back the heat shielding from the connector on the toast heat control.
    • Press down the metal tab on the connector using needle nose pliers or tweezers.
    • Do not try to peel the heat shielding back too far; it tears easily.
    • Repeat for each of the three connections on the control.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Alejandro Martin
339 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 5-11, Maness Fall 2015 Mitglied von Cal Poly, Team 5-11, Maness Fall 2015
CPSU-MANESS-F15S5G11
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
I got to removing the “back” cover. Black cover perhaps? There seem to be silver tabs from the front silver facing that are defeating my attempts to remove the cover.
Joe - Antwort
Hi Alejandro, could you tell me how to replace the heating elements. Or maybe just how to access them for better cleaning? Or maybe just suggestions on how to clean them while in place since they do rotate? Vinegar-water isn’t working. Thanks!!!
Ginny Lupo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 5
Letzten 7 Tage: 23
Letzten 30 Tage: 86
Insgesamt: 5,809
