Zum Hauptinhalt wechseln
Black and Decker TR1278B Lever Catch-Spring Replacement
Was du brauchst
  1. Black and Decker TR1278B Lever Catch-Spring Replacement, Top Cover: Schritt 1, Bild 1 von 1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Black and Decker TR1278B Lever Catch-Spring Replacement: Schritt 2, Bild 1 von 1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. Black and Decker TR1278B Lever Catch-Spring Replacement: Schritt 3, Bild 1 von 1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. Black and Decker TR1278B Lever Catch-Spring Replacement: Schritt 4, Bild 1 von 1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. Black and Decker TR1278B Lever Catch-Spring Replacement: Schritt 5, Bild 1 von 1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
  6. Black and Decker TR1278B Lever Catch-Spring Replacement, Lever Catch Spring: Schritt 6, Bild 1 von 1
    • Lift the top cover up and remove it from the toaster.
  7. Black and Decker TR1278B Lever Catch-Spring Replacement: Schritt 7, Bild 1 von 1
    • Locate the springs.
    • There is a top spring and bottom spring.
  8. Black and Decker TR1278B Lever Catch-Spring Replacement: Schritt 8, Bild 1 von 2 Black and Decker TR1278B Lever Catch-Spring Replacement: Schritt 8, Bild 2 von 2
    • Use needle nose tweezers to free one end of the spring.
    • Turn the spring until it is completely free.
  9. Black and Decker TR1278B Lever Catch-Spring Replacement: Schritt 9, Bild 1 von 1
    • Remove spring for replacement.
    • Repeat steps for bottom spring.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Brea-Monique
351 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 8-1, Eyestone Spring 2017 Mitglied von USF Tampa, Team 8-1, Eyestone Spring 2017
USFT-EYESTONE-S17S8G1
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Hi there, thanks for this guide. I have a little issue : one of the screws is quite unusual, probably because it’s not meant to be repaired by a poor peasant. It has a little pin in it and I can’t unscrew it with the tools I have. Any tips ?
ToasterMaster - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 24
Insgesamt: 1,319
