Zum Hauptinhalt wechseln
Black and Decker TR1278B Top Cover Replacement
Was du brauchst
  1. Black and Decker TR1278B Top Cover Replacement, Top Cover: Schritt 1, Bild 1 von 1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Black and Decker TR1278B Top Cover Replacement: Schritt 2, Bild 1 von 1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. Black and Decker TR1278B Top Cover Replacement: Schritt 3, Bild 1 von 1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. Black and Decker TR1278B Top Cover Replacement: Schritt 4, Bild 1 von 1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. Black and Decker TR1278B Top Cover Replacement: Schritt 5, Bild 1 von 1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 8-1, Eyestone Spring 2017 Mitglied von USF Tampa, Team 8-1, Eyestone Spring 2017
USFT-EYESTONE-S17S8G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 69
Insgesamt: 6,326
