Zum Hauptinhalt wechseln
Einleitung
Before replacing knobs you will have to disassemble oven to take off the knobs and faceplate.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Make sure that the toaster is unplugged before you begin.
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster upside down and remove the two Phillips #4 1 cm screws attached to the side panels.
  2. Pull down and out to remove side panels from the unit Repeat for the other side.
    • Pull down and out to remove side panels from the unit
    • Repeat for the other side.
  3. Remove the bottom vent.
    • Remove the bottom vent.
    • This should come off fairly easy.
  4. Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
    • Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
  5. Remove the crumb tray (bottom metal panel) from the toaster unit.
    • Remove the crumb tray (bottom metal panel) from the toaster unit.
  6. Remove the aluminum strip on the bottom of the unit.
    • Remove the aluminum strip on the bottom of the unit.
  7. Remove knobs by pulling up on them.
    • Remove knobs by pulling up on them.
  8. Unhook the bottom of the display panel from the toaster unit.
    • Unhook the bottom of the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful.
  9. Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
    • Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
Abschluss
To reassemble your toaster, follow these directions in reverse.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Jonathan
245 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 2-10, Propen Fall 2012 Mitglied von Cal Poly, Team 2-10, Propen Fall 2012
CPSU-PROPEN-F12S2G10
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 29
Insgesamt: 3,573
