Einleitung
Before replacing knobs you will have to disassemble oven to take off the knobs and faceplate.
Was du brauchst
Turn the toaster upside down and remove the two Phillips #4 1 cm screws attached to the side panels.
Pull down and out to remove side panels from the unit
Repeat for the other side.
Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
To reassemble your toaster, follow these directions in reverse.
Eine weitere Person hat diese Anleitung absolviert.
