Einleitung
In order to replace to On/Off switch, you will once again have to take apart the whole unit to get to that part.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Turn the toaster over with its backside face down.
Remove the two Phillips #4 1cm screws that attach the side panels.
Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
Remove the knobs by pulling them upward; they should slide right off.
When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
Begin to detach the back panel from the toaster unit.
Then, unhook the rest of the display panel.
Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
Remove the two Phillips #4 1 cm screws that were under the faceplate.
To reassemble your device, follow these instructions in reverse order. It will look like the faceplate is still bent out, but after you put the screws back in it will come back into place.
2 weitere Nutzer haben diese Anleitung absolviert.
