Zum Hauptinhalt wechseln
BlackBerry 7130e battery replacement
Was du brauchst
  1. BlackBerry 7130e battery replacement, battery: Schritt 1, Bild 1 von 1
    • Turn the phone over so that the screen is facing the work surface
  2. BlackBerry 7130e battery replacement: Schritt 2, Bild 1 von 1
    • Press your thumb against the battery latch. While pressing on latch, slide off battery cover towards the bottom of the phone.
    • You may need to apply considerable force on the latch at the bottom of the phone to complete this successfully.
  3. BlackBerry 7130e battery replacement: Schritt 3, Bild 1 von 1
    • Remove the battery by pushing downward on the area where prongs connect to bottom inside of the phone while using a thumb, finger, or tool to pull on the top of the battery to lift it out.
Abschluss
Sean Tiernan
5 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 3-16, Maness Winter 2010 Mitglied von Cal Poly, Team 3-16, Maness Winter 2010
CPSU-MANESS-W10S3G16
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 2,997
