Einleitung
The outer shell of the BlackBerry 7280 contains two parts, the back case and the front case. This guide demonstrates how to remove the front case by unscrewing the supporting bracket and then prying the front case away.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
With your thumb press down on the locking- button on the back of the BlackBerry 7280.
Slide the battery cover off the device.
Remove the lithium-ion battery from the back of the device using your index finger.
Hold the device with both hands.
Lift the SIM card holder using your thumb and index finger.
Remove the SIM card from the device.
Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
