Zum Hauptinhalt wechseln
BlackBerry 7280 Inner Keyboard Replacement
Was du brauchst
  1. BlackBerry 7280 Inner Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 BlackBerry 7280 Inner Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 BlackBerry 7280 Inner Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
    • Slide the battery cover off the device.
  2. BlackBerry 7280 Inner Keyboard Replacement: Schritt 2, Bild 1 von 2 BlackBerry 7280 Inner Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the lithium-ion battery from the back of the device using your index finger.
  3. BlackBerry 7280 Inner Keyboard Replacement, SIM Card: Schritt 3, Bild 1 von 3 BlackBerry 7280 Inner Keyboard Replacement, SIM Card: Schritt 3, Bild 2 von 3 BlackBerry 7280 Inner Keyboard Replacement, SIM Card: Schritt 3, Bild 3 von 3
    • Hold the device with both hands.
    • Lift the SIM card holder using your thumb and index finger.
    • Remove the SIM card from the device.
  4. BlackBerry 7280 Inner Keyboard Replacement, Back Case: Schritt 4, Bild 1 von 2 BlackBerry 7280 Inner Keyboard Replacement, Back Case: Schritt 4, Bild 2 von 2
    • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
    • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
  5. BlackBerry 7280 Inner Keyboard Replacement: Schritt 5, Bild 1 von 2 BlackBerry 7280 Inner Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Use the plastic opening tool to pry the back case away from the front case.
  6. BlackBerry 7280 Inner Keyboard Replacement, Front Case: Schritt 6, Bild 1 von 2 BlackBerry 7280 Inner Keyboard Replacement, Front Case: Schritt 6, Bild 2 von 2
    • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
  7. BlackBerry 7280 Inner Keyboard Replacement: Schritt 7, Bild 1 von 2 BlackBerry 7280 Inner Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the front plastic case from the metal bracket.
  8. BlackBerry 7280 Inner Keyboard Replacement, Inner Keyboard: Schritt 8, Bild 1 von 1
    • To remove the inner keyboard, simply peel it off of the logic board as shown.
Abschluss
Clemson, Team 12-2, Benson Spring 2013 Mitglied von Clemson, Team 12-2, Benson Spring 2013
CLEM-BENSON-S13S12G2
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 270
