Einleitung
Use this guide to replace the keypad buttons of your BlackBerry 7290 .
Was du brauchst
Apply pressure to the lock button on the back of the device.
Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
Locate groove along the right side of the battery compartment.
Remove battery by prying between the battery and the groove.
Lift the SIM card holder up.
Gently remove the SIM card from the SIM card holder by sliding the card along the railing.
Locate the four screws along the perimeter of the back casing.
Remove the four top screws using a T-6 torx screwdriver.
Locate two screws within the lower edge of the inner compartment.
Remove the two bottom screws using a T-6 torx screwdriver.
Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
Remove the back casing from the phone by lifting the unhooked portion, then slide the casing towards the top of the device.
Locate on the backside of the phone, a screw towards the top of the device.
Using a T-6 screwdriver, remove the screw.
After the screw has been removed, carefully lift the side button brace to reveal the side button.
To remove the phone's internals, start by loosening one side by pulling gently.
With one side loosened, simply lift the phone internals to separate from the front casing.
2 weitere Personen haben diese Anleitung absolviert.
