Einleitung
This guide demonstrates how to remove and replace the LCD screen.
Was du brauchst
Remove the six T6 Torx screws on the back of the phone.
Make sure to keep the screws somewhere that they will not get lost.
Using your finger nail or a spudger, carefully pry up the back cover.
Begin in one spot and slowly circle around the device as you pry up all of the back cover.
Carefully pry off front cover. Make sure the plastic clips are unlatched before applying force.
Lift off front cover from metal plate.
