Zum Hauptinhalt wechseln
BlackBerry 7510 Logic Board Replacement
Was du brauchst
  1. BlackBerry 7510 Logic Board Replacement, Back Face of Phone: Schritt 1, Bild 1 von 1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 Logic Board Replacement: Schritt 2, Bild 1 von 1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 Logic Board Replacement: Schritt 3, Bild 1 von 1
    • Lift off the back cover.
  4. BlackBerry 7510 Logic Board Replacement: Schritt 4, Bild 1 von 1
    • Remove the two T6 screws.
  5. BlackBerry 7510 Logic Board Replacement: Schritt 5, Bild 1 von 2 BlackBerry 7510 Logic Board Replacement: Schritt 5, Bild 2 von 2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 Logic Board Replacement, Logic Board: Schritt 6, Bild 1 von 1
    • Using the T6 Torx screwdriver, remove the top screw.
  7. BlackBerry 7510 Logic Board Replacement: Schritt 7, Bild 1 von 1
    • Using your spudger, carefully pry off back plate.
    • Use the same technique as with the plastic back cover. Circle around the back plate until all of it is pried up.
  8. BlackBerry 7510 Logic Board Replacement: Schritt 8, Bild 1 von 1
    • Remove the front cover and keypad.
  9. BlackBerry 7510 Logic Board Replacement: Schritt 9, Bild 1 von 1
    • Remove one T6 Torx screw in the front bottom right of the board.
  10. BlackBerry 7510 Logic Board Replacement: Schritt 10, Bild 1 von 2 BlackBerry 7510 Logic Board Replacement: Schritt 10, Bild 2 von 2
    • Carefully pry the screen from the board with your spudger.
    • After prying it up, remove the screen from the board.
  11. BlackBerry 7510 Logic Board Replacement: Schritt 11, Bild 1 von 2 BlackBerry 7510 Logic Board Replacement: Schritt 11, Bild 2 von 2
    • Unscrew center T6 Torx screw in the center of the logic board.
    • Remove the logic board from the phone.
    • Replace with new logic board.
Abschluss
Neil Johnson
12 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 14-44, Regan Winter 2010 Mitglied von Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 1,850
