Einleitung
This is a guide on how to replace the logic board on your Blackberry 7510.
Was du brauchst
Remove the six T6 Torx screws on the back of the phone.
Make sure to keep the screws somewhere that they will not get lost.
Using your finger nail or a spudger, carefully pry up the back cover.
Begin in one spot and slowly circle around the device as you pry up all of the back cover.
Using your spudger, carefully pry off back plate.
Use the same technique as with the plastic back cover. Circle around the back plate until all of it is pried up.
Carefully pry the screen from the board with your spudger.
After prying it up, remove the screen from the board.
Unscrew center T6 Torx screw in the center of the logic board.
Remove the logic board from the phone.
Replace with new logic board.
