Zum Hauptinhalt wechseln
BlackBerry 8703e Battery Replacement
Was du brauchst
  1. BlackBerry 8703e Battery Replacement, Battery: Schritt 1, Bild 1 von 2 BlackBerry 8703e Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Position your phone like the first image so that the highlighted button is on your left.
    • Slide the battery cover to the left while pressing the button with one hand and applying pressure on the center of the phone with your other hand.
    • Remove the cover completely and set it aside.
  2. BlackBerry 8703e Battery Replacement: Schritt 2, Bild 1 von 1
    • Position your phone like the image to the left, then locate the rectangular battery in the middle of the phone.
    • Locate the notch on the top right of the battery compartment.
    • Slide your fingernail or the flat end of a Spudger in the notch, then lift upwards on the top of the battery to remove it from the phone.
    • Set the battery aside and out of the way.
Abschluss
Cal Poly, Team 11-3, Forte Winter 2010 Mitglied von Cal Poly, Team 11-3, Forte Winter 2010
CPSU-FORTE-W10S11G3
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 3,417
