Einleitung
This guide will show you how to replace the keyboard of the BlackBerry 8820. In order to do so, you must have a 1/16" diameter torx screwdriver and a plastic opening tool.
Was du brauchst
Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
Remove the battery by prying under it with your finger or the plastic opening tool.
Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
Slide the keyboard downwards, as shown.
The keyboard will detach from the casing with a small amount of pressure.
Slide the new keyboard into the casing. If done correctly, it should click into place and stay secure.
3 weitere Personen haben diese Anleitung absolviert.
