Zum Hauptinhalt wechseln
BlackBerry 8820 LCD Screen Replacement
Was du brauchst
  1. BlackBerry 8820 LCD Screen Replacement, Disassembling BlackBerry 8820 Outer Casing: Schritt 1, Bild 1 von 1
    • Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
  2. BlackBerry 8820 LCD Screen Replacement: Schritt 2, Bild 1 von 2 BlackBerry 8820 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery by prying under it with your finger or the plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 LCD Screen Replacement: Schritt 3, Bild 1 von 2 BlackBerry 8820 LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Use a nylon spudger to carefully remove the two side bars of plastic.
  4. BlackBerry 8820 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Use a nylon spudger to carefully pry the back casing off.
    • There are two small clamps on each edge that need to be unhooked before the casing will come off.
  5. BlackBerry 8820 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Pry off the front casing.
    • Be aware of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 LCD Screen Replacement, LCD Screen: Schritt 6, Bild 1 von 1
    • After disassembling the outer casing, the phone should be stripped as shown.
  7. BlackBerry 8820 LCD Screen Replacement: Schritt 7, Bild 1 von 2 BlackBerry 8820 LCD Screen Replacement: Schritt 7, Bild 2 von 2
    • At the top of the phone, locate the gloss SATA cable strap connecting the LCD screen to the phone.
    • Using the prying tool, unattach this cable by levering under the connector.
  8. BlackBerry 8820 LCD Screen Replacement: Schritt 8, Bild 1 von 2 BlackBerry 8820 LCD Screen Replacement: Schritt 8, Bild 2 von 2
    • Using the prying tool, lever up the old screen as shown.
    • WARNING: Be sure to have disconnected the SATA cable strap prior to attempting this.
  9. BlackBerry 8820 LCD Screen Replacement: Schritt 9, Bild 1 von 2 BlackBerry 8820 LCD Screen Replacement: Schritt 9, Bild 2 von 2
    • Insert new LCD screen.
    • Attach cable to the connector located at the top of the phone.
    • Phone should look as it was prior to screen removal.
Abschluss
ryan
44 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 13-64, Johann Spring 2013 Mitglied von Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 612
