Zum Hauptinhalt wechseln
BlackBerry Bold 9700 Keyboard Replacement
Was du brauchst
  1. BlackBerry Bold 9700 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Remove the back panel by sliding it downward and lifting it away from the phone.
  2. BlackBerry Bold 9700 Keyboard Replacement: Schritt 2, Bild 1 von 3 BlackBerry Bold 9700 Keyboard Replacement: Schritt 2, Bild 2 von 3 BlackBerry Bold 9700 Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Remove the battery by lifting the bottom edge of the battery from the bottom of the phone and up from the case.
    • (Warning: Power-off the device before removing the battery.)
  3. BlackBerry Bold 9700 Keyboard Replacement: Schritt 3, Bild 1 von 3 BlackBerry Bold 9700 Keyboard Replacement: Schritt 3, Bild 2 von 3 BlackBerry Bold 9700 Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Remove the SIM card by pushing the card vertically through the bracket towards the top of the device.
    • The SIM card MUST be removed to disassemble the device.
  4. BlackBerry Bold 9700 Keyboard Replacement: Schritt 4, Bild 1 von 3 BlackBerry Bold 9700 Keyboard Replacement: Schritt 4, Bild 2 von 3 BlackBerry Bold 9700 Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Use the plastic opening tool to gently pry the bottom panel with the AT&T logo away from the phone.
    • Note: You will hear a snapping sound.
  5. BlackBerry Bold 9700 Keyboard Replacement: Schritt 5, Bild 1 von 3 BlackBerry Bold 9700 Keyboard Replacement: Schritt 5, Bild 2 von 3 BlackBerry Bold 9700 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Remove the front panel 5.57mm Torx head screws x2 with the T5 Torx screwdriver.
  6. BlackBerry Bold 9700 Keyboard Replacement: Schritt 6, Bild 1 von 3 BlackBerry Bold 9700 Keyboard Replacement: Schritt 6, Bild 2 von 3 BlackBerry Bold 9700 Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Use the plastic opening tool to remove the frame.
    • This will take a bit of effort. You will hear a snapping sound.
  7. BlackBerry Bold 9700 Keyboard Replacement: Schritt 7, Bild 1 von 3 BlackBerry Bold 9700 Keyboard Replacement: Schritt 7, Bild 2 von 3 BlackBerry Bold 9700 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Gently lift the bottom of the keyboard up with your fingers and pull it toward the bottom of the phone.
  8. BlackBerry Bold 9700 Keyboard Replacement: Schritt 8, Bild 1 von 3 BlackBerry Bold 9700 Keyboard Replacement: Schritt 8, Bild 2 von 3 BlackBerry Bold 9700 Keyboard Replacement: Schritt 8, Bild 3 von 3
    • Align the new keyboard to the bottom of the screen with the track pad slot angled downward.
    • Once the keyboard is flush with the screen, push the keyboard into place.
Abschluss
To reassemble your device, follow these steps in reverse.
Danny
365 Reputation
3 Anleitungen geschrieben
Colorado Springs, Team 9-3, Panko Spring 2015 Mitglied von Colorado Springs, Team 9-3, Panko Spring 2015
UCCS-PANKO-S15S9G3
2 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 1,223
