Einleitung
Replacing the keyboard of the BlackBerry Bold 9700 is one of the easier repairs you will do. All it takes is a bit of prying and a screwdriver. The process of replacing the keyboard of your BlackBerry Bold 9700 will allow you to become familiar with your device and restore full functionality.
Was du brauchst
Remove the back panel by sliding it downward and lifting it away from the phone.
Remove the battery by lifting the bottom edge of the battery from the bottom of the phone and up from the case.
(Warning: Power-off the device before removing the battery.)
Remove the SIM card by pushing the card vertically through the bracket towards the top of the device.
Use the plastic opening tool to gently pry the bottom panel with the AT&T logo away from the phone.
Note: You will hear a snapping sound.
Remove the front panel 5.57mm Torx head screws x2 with the T5 Torx screwdriver.
Gently lift the bottom of the keyboard up with your fingers and pull it toward the bottom of the phone.
Align the new keyboard to the bottom of the screen with the track pad slot angled downward.
Once the keyboard is flush with the screen, push the keyboard into place.
To reassemble your device, follow these steps in reverse.
