Einleitung
The process of replacing the trackpad of your BlackBerry Bold 9700 will allow you to become familiar with your device and restore full functionality.
Was du brauchst
Remove the battery by prying the bottom of the battery upward.
Once the battery is angled up, pull it away from the top of the device.
Slide the SIM card from underneath the holding bracket upward toward the battery connector pins.
Use your T5 Torx screwdriver to remove the two black 5.57mm Torx head screws underneath the keyboard.
Use the plastic opening tool to remove the frame of your device.
Once the case is loosened from the device, slide the case away from the top of the phone.
Gently lift the bottom of the keyboard upward.
Pull the keyboard away from the bottom of the LCD display and lift upward.
Gently pry up the ribbon connector at the top of the phone with a plastic opening tool.
Remove the top two Torx head 4.13mm steel screws with your T5 Torx screwdriver.
Lift the clear plastic cover directly upward.
Grip the motherboard by the screen
Lift the board away from the base of the housing and vertically up.
Flip the board over so that the LCD display is against the the surface of your work space.
Use a plastic opening tool to gently remove the ribbon connector located on the right-hand side of the board.
Gently grip the trackpad.
Pull the ribbon cable through the slot in the board.
Insert the ribbon connector of your new trackpad through the slot in the board.
Align the ribbon connector with the connection point.
Gently press the ribbon connector into place.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
