Was du brauchst
Press down on the battery release button and slide the back cover up with your thumb.
Slide the metal sim card cover to the unlock position.
Remove the sim card.
Use a spudger to pry the front cover away from the side panels.
Work the spudger around the entire phone until the front cover is free.
Remove the four T6 Torx screws located on the corners of the keyboard frame.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
