Ersatzteile
Kein Ersatzteil erforderlich.
  1. Press down on the battery release button and slide the back cover up with your thumb.
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. Pry from the top of the battery to pull it out.
    • Pry from the top of the battery to pull it out.
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
Abschluss
Sean Willis
Mitglied seit 26.01.2012
229 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 10-32, Amido Winter 2012 Mitglied von Cal Poly, Team 10-32, Amido Winter 2012
CPSU-AMIDO-W12S10G32
4 Mitglieder
7 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 885
