Einleitung
Follow this guide to replace the motherboard on a Blackberry Curve 8900. The motherboard is a crucial component to keep the phone functioning correctly. If the Blackberry Curve 8900 randomly powers down or unexplainably malfunctions, it might be time for a replacement. To find a replacement, it is recommended to search for the part online using the device name (Blackberry Curve 8900) and the part (motherboard). This guide requires the small iFixit opening tool, a T6 Torx Screwdriver and a gentle touch. This simple 10-step guide is beginner friendly, allowing for an easy replacement.
Was du brauchst
Pinch the battery at the grey semi-circles on the top left and top right corners of the battery using your fingers and remove it from the device.
Remove the six screws from the mid-frame of the device, using the T6 Torx Screwdriver.
Gently remove the mid-frame from the phone, exposing the motherboard.
This is the motherboard.
Gently pull back the plastic tabs that secure the motherboard to the case.
Slowly pull the tabs, working your way around the case, until they are lifted and the motherboard is free.
Remove the motherboard.
Carefully detach the antenna from the two clips on the side of the motherboard.
Disconnect the antenna from the motherboard in the same manner.
Carefully disconnect the ribbon cable located on the bottom right of the motherboard.
Locate the chip underneath the screen.
Gently remove the screen, without applying too much pressure, taking care not to damage it.
Lift up the motherboard from the bottom edge to reveal the ribbon cables.
Carefully disconnect the two ribbon cables connecting the motherboard to the display on either side.
Remove the motherboard and place off to the side.
3 weitere Personen haben diese Anleitung absolviert.
