Werkzeuge
Ersatzteile
On both sides of the battery, there are light grey half-circles. Using your fingers, pinch the battery along the grey half-circles and remove it from the device.
Gently pull back the plastic tabs that secure the motherboard to the case.
Slowly work your way around the case until the tabs are lifted and the motherboard is free.
Remove the motherboard.
Carefully detach the antenna from the two clips on the side of the motherboard.
In the same manner, disconnect the antenna from the motherboard.
Carefully disconnect the ribbon cable located on the bottom right of the motherboard.
Lift up the motherboard from the bottom edge to reveal the ribbon cables.
Carefully disconnect the two ribbon cables connecting the motherboard to the display.
3 weitere Nutzer haben diese Anleitung absolviert.
