Zum Hauptinhalt wechseln
BlackBerry KeyONE partial Disassembly
Was du brauchst
  1. BlackBerry KeyONE partial Disassembly, Remove top cover: Schritt 1, Bild 1 von 1
    • Carefully remove the top plastic cover. It is held in place by adhesive.
  2. BlackBerry KeyONE partial Disassembly, Remove top frame: Schritt 2, Bild 1 von 2 BlackBerry KeyONE partial Disassembly, Remove top frame: Schritt 2, Bild 2 von 2
    • Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off.
  3. BlackBerry KeyONE partial Disassembly, Remove back cover: Schritt 3, Bild 1 von 1
    • Remove the back cover. It mostly just clips off, but has some adhesive in the lower area.
  4. BlackBerry KeyONE partial Disassembly, Disconnect Battery: Schritt 4, Bild 1 von 2 BlackBerry KeyONE partial Disassembly, Disconnect Battery: Schritt 4, Bild 2 von 2
    • Remove the two Philipps #0 screws securing the battery connector and unplug the later.
  5. BlackBerry KeyONE partial Disassembly: Schritt 5, Bild 1 von 1
    • Remove the 6 Philipps #0 screws securing the lower cover and remove it.
    • Remove the three Philipps #0 screws holding down the bar that secures the two main lego-style plugs and remove it.
  6. BlackBerry KeyONE partial Disassembly, Remove top cover: Schritt 6, Bild 1 von 1
    • Remove the three Philipps #0 screws securing the upper cover and remove it.
  7. BlackBerry KeyONE partial Disassembly: Schritt 7, Bild 1 von 1
    • Unplug the remaining ribbon cables
    • Remove the last three Philipps #0 screws securing the Motherbard.
    • Now you should be able to replace most components.
    • The screen is held in place from the front by adhesive (or not, in the earlier versions), its cable slides trough the phone to the PCB - It's the large connector in the middle.
    • The battery is glued to the frame firmly. There are three pultabs located underneath the motherboard.
    • Don't forget to remove the sim-tray if you're removing the motherboard.
Abschluss
14 weitere Nutzer:innen haben diese Anleitung absolviert.
raven
1.080 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 22
Letzte 30 Tage: 62
Insgesamt: 9,463
