Einleitung
This guide will cover the steps required to access and replace the speakers on each side of the device. Speakers are replaced one-by-one and can be done in any order.
Was du brauchst
Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
Remove 1.55x.33mm Phillips screw from the metal frame.
Remove 1.5x4.25mm Phillips screw from speaker bar.
Peel off the stickers holding the left speaker in place with a tweezer or by using your fingers
Remove both 1.5x4.25mm Phillips screws from the right speaker bar by using the Phillips Screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
