Zum Hauptinhalt wechseln
BlackBerry PlayBook Speaker Replacement
Was du brauchst
  1. BlackBerry PlayBook Speaker Replacement, Remove Back Panel: Schritt 1, Bild 1 von 2 BlackBerry PlayBook Speaker Replacement, Remove Back Panel: Schritt 1, Bild 2 von 2
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. BlackBerry PlayBook Speaker Replacement, Unscrew Left Speaker: Schritt 2, Bild 1 von 1
    • Remove 1.55x.33mm Phillips screw from the metal frame.
    • Remove 1.5x4.25mm Phillips screw from speaker bar.
  3. BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: Schritt 3, Bild 1 von 2 BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: Schritt 3, Bild 2 von 2
    • Peel off the stickers holding the left speaker in place with a tweezer or by using your fingers
  4. BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: Schritt 4, Bild 1 von 2 BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: Schritt 4, Bild 2 von 2
    • Slide the left speaker bar out from its metal bracket.
  5. BlackBerry PlayBook Speaker Replacement, Unscrew Right Speaker: Schritt 5, Bild 1 von 1
    • Remove both 1.5x4.25mm Phillips screws from the right speaker bar by using the Phillips Screwdriver.
  6. BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: Schritt 6, Bild 1 von 2 BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: Schritt 6, Bild 2 von 2
    • Lift the right speaker bar to remove it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Nathan
661 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 14-27, Maness Fall 2014 Mitglied von Cal Poly, Team 14-27, Maness Fall 2014
CPSU-MANESS-F14S14G27
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 17
Insgesamt: 986
