Zum Hauptinhalt wechseln
Einleitung
If you're internal battery dies, use this guide to replace it.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use a T9 Screwdriver to unscrew the two screws on the backside of the BlackBerry, one on the bottom left and one on the top right.
    • Use a T9 Screwdriver to unscrew the two screws on the backside of the BlackBerry, one on the bottom left and one on the top right.
  2. Remove the backside of the device and set aside for later use.
    • Remove the backside of the device and set aside for later use.
  3. Remove the rubber placement pad that sits under the battery and set aside for later use. Gently fold back the battery, making sure the small plug connecting the battery to the logic board remains intact. Extra care should be taken as this part is quite delicate and easy to damage. Remove the rubber placement pad that sits under the battery and set aside for later use. Gently fold back the battery, making sure the small plug connecting the battery to the logic board remains intact. Extra care should be taken as this part is quite delicate and easy to damage.
    • Remove the rubber placement pad that sits under the battery and set aside for later use. Gently fold back the battery, making sure the small plug connecting the battery to the logic board remains intact. Extra care should be taken as this part is quite delicate and easy to damage.
  4. Use the T9 Screwdriver to remove the five visible screws: Top right, bottom right, middle center, bottom center, bottom left.
    • Use the T9 Screwdriver to remove the five visible screws: Top right, bottom right, middle center, bottom center, bottom left.
  5. Carefully remove the board from the device by gently pushing on the screen from the front side. The battery, screen, and scroll wheel are all connected to the logic board. Be sure to support these components so they do not break. Note the placement of two additional rubber pieces that cling loosely to the logic board. It is okay to let these pieces fall loose.
    • Carefully remove the board from the device by gently pushing on the screen from the front side. The battery, screen, and scroll wheel are all connected to the logic board. Be sure to support these components so they do not break.
    • Note the placement of two additional rubber pieces that cling loosely to the logic board. It is okay to let these pieces fall loose.
    • One is located below the scrollwheel.
    • Another is located behind the screen.
  6. Disconnect the power conductor by gently peeling the grey section (which is connected to the logic board) upwards.
    • Disconnect the power conductor by gently peeling the grey section (which is connected to the logic board) upwards.
  7. The conductor can now be easily removed by pulling it off of the logic board.
    • The conductor can now be easily removed by pulling it off of the logic board.
  8. Gently pull on the wires connecting the battery to the device until the battery disconnects. Gently pull on the wires connecting the battery to the device until the battery disconnects.
    • Gently pull on the wires connecting the battery to the device until the battery disconnects.
Abschluss
Steven Jackowski
1 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 33-83, Johann Spring 2010 Mitglied von Cal Poly, Team 33-83, Johann Spring 2010
CPSU-JOHANN-S10S33G83
4 Mitglieder
What is the replacement battery
hoghead4734 - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 2,166
