Was du brauchst
Depress the battery cover release button and remove the battery cover
Remove the battery from the phone before continuing.
Slide the yellow button toward the battery to eject the SIM card
Remove the MicroSD card from the SD slot (if present)
There will be a silver bezel around the edge (the dog ate mine!)
Insert pry tool near the padlock icon and gently work your way around the bezel to pry it off and reveal the screws.
With the 8 screws removed, you can gently pry the back cover off. Be gentle, as it is still connected by a ribbon cable
Gently pry ribbon cable off, and then you will have the back cover fully removed
The next step is to remove the board.
There are 3 ribbon cables connected to it
Disconnect the first ribbon cable
When you remove the second ribbon cable it will reveal the third ribbon cable
With the 3 ribbon cables disconnected you can gently pry the board up and away from phone
With the board removed, you can then simply lift out the LCD display
7 weitere Personen haben diese Anleitung absolviert.
