Was du brauchst
Turn phone over to the backside.
Press down on the lower portion of the back cover.
Slide the lower portion down to remove the cover and reveal the battery.
Once the battery is removed, remove the four 9.2 mm screws with the T4 Torx Screwdriver.
Remove side panels with the Plastic Opening Tool by sliding it along the edge of the panel until you can pry it off with the tool.
Locate the two 9.2mm screws on the upper inside casing
Remove them using the T4 Torx Screwdriver
Slide off the front casing once the screws are removed.
Once the microphone is revealed, use the flathead screwdriver, or the tip of a knife, to carefully pry the microphone out of the hole.
