Zum Hauptinhalt wechseln
BlackBerry World Edition 8830 Microphone Replacement
Was du brauchst
  1. BlackBerry World Edition 8830 Microphone Replacement, Battery: Schritt 1, Bild 1 von 3 BlackBerry World Edition 8830 Microphone Replacement, Battery: Schritt 1, Bild 2 von 3 BlackBerry World Edition 8830 Microphone Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before beginning this installation, make sure phone is powered off .
    • Turn phone over to the backside.
    • Press down on the lower portion of the back cover.
    • Slide the lower portion down to remove the cover and reveal the battery.
  2. BlackBerry World Edition 8830 Microphone Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery from the phone.
  3. BlackBerry World Edition 8830 Microphone Replacement, Front and Back Casing: Schritt 3, Bild 1 von 2 BlackBerry World Edition 8830 Microphone Replacement, Front and Back Casing: Schritt 3, Bild 2 von 2
    • Once the battery is removed, remove the four 9.2 mm screws with the T4 Torx Screwdriver.
  4. BlackBerry World Edition 8830 Microphone Replacement: Schritt 4, Bild 1 von 3 BlackBerry World Edition 8830 Microphone Replacement: Schritt 4, Bild 2 von 3 BlackBerry World Edition 8830 Microphone Replacement: Schritt 4, Bild 3 von 3
    • Remove side panels with the Plastic Opening Tool by sliding it along the edge of the panel until you can pry it off with the tool.
  5. BlackBerry World Edition 8830 Microphone Replacement: Schritt 5, Bild 1 von 2 BlackBerry World Edition 8830 Microphone Replacement: Schritt 5, Bild 2 von 2
    • Remove the back casing using the Plastic Opening Tool
    • Once the back casing is removed the top two buttons are likely to pop out.
  6. BlackBerry World Edition 8830 Microphone Replacement: Schritt 6, Bild 1 von 3 BlackBerry World Edition 8830 Microphone Replacement: Schritt 6, Bild 2 von 3 BlackBerry World Edition 8830 Microphone Replacement: Schritt 6, Bild 3 von 3
    • Locate the two 9.2mm screws on the upper inside casing
    • Remove them using the T4 Torx Screwdriver
    • Slide off the front casing once the screws are removed.
    • Trackball will fall out once the casing is removed.
  7. BlackBerry World Edition 8830 Microphone Replacement, Microphone: Schritt 7, Bild 1 von 2 BlackBerry World Edition 8830 Microphone Replacement, Microphone: Schritt 7, Bild 2 von 2
    • Once the microphone is revealed, use the flathead screwdriver, or the tip of a knife, to carefully pry the microphone out of the hole.
    • Be careful not to bend the ring around the microphone when prying it out. If the ring does get bent you may not be able to replace the microphone.
Abschluss
tbace
28 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 17-27, Amido Spring 2012 Mitglied von Cal Poly, Team 17-27, Amido Spring 2012
CPSU-AMIDO-S12S17G27
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 760
