Zum Hauptinhalt wechseln
Blackberry 7105t Speaker Replacement
Was du brauchst
  1. Blackberry 7105t Speaker Replacement, Blackberry 7105t Disassembly: Schritt 1, Bild 1 von 1
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Blackberry 7105t Speaker Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Blackberry 7105t Speaker Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Blackberry 7105t Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. Blackberry 7105t Speaker Replacement: Schritt 5, Bild 1 von 3 Blackberry 7105t Speaker Replacement: Schritt 5, Bild 2 von 3 Blackberry 7105t Speaker Replacement: Schritt 5, Bild 3 von 3
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  6. Blackberry 7105t Speaker Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  7. Blackberry 7105t Speaker Replacement: Schritt 7, Bild 1 von 1
    • The black battery casing and logic board can now be separated for the following steps.
  8. Blackberry 7105t Speaker Replacement, Speaker: Schritt 8, Bild 1 von 2 Blackberry 7105t Speaker Replacement, Speaker: Schritt 8, Bild 2 von 2
    • With the speaker facing towards you, use a spudger to unfasten the three clips indicated in the picture.
    • Place the three clips in plastic bag and set aside.
    • Once clips are removed, you will have full access to remove the speaker.
Abschluss
CeeJay
19 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 9-17, Regan Fall 2009 Mitglied von Cal Poly, Team 9-17, Regan Fall 2009
CPSU-REGAN-F09S9G17
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 1,191
