Einleitung
Disassembling the motherboard in the rear of the Blackberry allows you to get to the LCD screen and keypad.
Was du brauchst
Turn the phone upside down.
Push down on the black button on the back of the phone to slide the rear panel off.
The battery should be visible now.
Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
Use a pick or plastic opening tool to push the clips holding the rear away from you.
Repeat the process of unlatching the clips for the top section of the Blackberry.
Remove the motherboard.
Remove the indicated screw using the T6 Torx screwdriver.
Place the faceplate face-down and the interior of the phone face-up, as shown.
