Zum Hauptinhalt wechseln
Blackberry 7520 Motherboard Replacement
Was du brauchst
  1. Blackberry 7520 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 Blackberry 7520 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Blackberry 7520 Motherboard Replacement: Schritt 2, Bild 1 von 3 Blackberry 7520 Motherboard Replacement: Schritt 2, Bild 2 von 3 Blackberry 7520 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. Blackberry 7520 Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 2 Blackberry 7520 Motherboard Replacement, Motherboard: Schritt 3, Bild 2 von 2
    • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
  4. Blackberry 7520 Motherboard Replacement: Schritt 4, Bild 1 von 2 Blackberry 7520 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Use a pick or plastic opening tool to push the clips holding the rear away from you.
    • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
  5. Blackberry 7520 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
  6. Blackberry 7520 Motherboard Replacement: Schritt 6, Bild 1 von 2 Blackberry 7520 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Slide the rear panel forward to reveal the motherboard.
  7. Blackberry 7520 Motherboard Replacement: Schritt 7, Bild 1 von 2 Blackberry 7520 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the indicated screws using a T6 Torx screwdriver.
  8. Blackberry 7520 Motherboard Replacement: Schritt 8, Bild 1 von 2 Blackberry 7520 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove the motherboard.
    • Remove the indicated screw using the T6 Torx screwdriver.
  9. Blackberry 7520 Motherboard Replacement: Schritt 9, Bild 1 von 2 Blackberry 7520 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Pull the metal plate away from the front panel of the cell phone.
  10. Blackberry 7520 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Place the faceplate face-down and the interior of the phone face-up, as shown.
Abschluss
Nathan
31 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 5-7, Forte Winter 2010 Mitglied von Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 17
Insgesamt: 3,597
