Zum Hauptinhalt wechseln
Blackberry 7520 SIM Card Replacement
  1. Blackberry 7520 SIM Card Replacement, Battery: Schritt 1, Bild 1 von 2 Blackberry 7520 SIM Card Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Blackberry 7520 SIM Card Replacement: Schritt 2, Bild 1 von 3 Blackberry 7520 SIM Card Replacement: Schritt 2, Bild 2 von 3 Blackberry 7520 SIM Card Replacement: Schritt 2, Bild 3 von 3
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. Blackberry 7520 SIM Card Replacement, SIM Card: Schritt 3, Bild 1 von 3 Blackberry 7520 SIM Card Replacement, SIM Card: Schritt 3, Bild 2 von 3 Blackberry 7520 SIM Card Replacement, SIM Card: Schritt 3, Bild 3 von 3
    • Push back on the black slot, then grab hold on top of the black slot and pull back so the SIM card and black slot pull back.
  4. Blackberry 7520 SIM Card Replacement: Schritt 4, Bild 1 von 2 Blackberry 7520 SIM Card Replacement: Schritt 4, Bild 2 von 2
    • Remove the SIM card by sliding it out of the black tray.
    • Insert the replacement SIM card with the gold plated side with lines facing down. Fold the black tray down with the SIM card in and push forward until the tray "slides" into place.
Abschluss
Nathan
31 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 5-7, Forte Winter 2010 Mitglied von Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 4,075
