Zum Hauptinhalt wechseln
Blackberry Bold 9000 Volume Toggle Replacement
Was du brauchst
  1. Blackberry Bold 9000 Volume Toggle Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Volume Toggle Replacement: Schritt 2, Bild 1 von 1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Volume Toggle Replacement: Schritt 3, Bild 1 von 1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Volume Toggle Replacement, Rear Case: Schritt 4, Bild 1 von 1
    • Remove the SIM card.
  5. Blackberry Bold 9000 Volume Toggle Replacement: Schritt 5, Bild 1 von 1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Volume Toggle Replacement: Schritt 6, Bild 1 von 1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Volume Toggle Replacement, Volume Toggle: Schritt 7, Bild 1 von 1
    • Lift out the motherboard assembly using the plastic opening tool, prying at all four sides of the device.
    • Try to remove from left to right, using caution with the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Volume Toggle Replacement: Schritt 8, Bild 1 von 1
    • Locate the volume toggle on the main frame of the phone.
    • Using the spudger, push the toggle in from the outside and remove.
  9. Blackberry Bold 9000 Volume Toggle Replacement: Schritt 9, Bild 1 von 1
    • Place the new toggle in, using the pointed end of the spudger to attach the toggle to the upper and lower pins.
    • Make sure the toggle is completely in place by pressing it outward into the frame.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Kelly
566 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 8-17, Maness Winter 2012 Mitglied von Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 2,464
