Ersatzteile
Kein Ersatzteil erforderlich.
Turn the device upside down.
Using your finger, slide the silver cover release button towards the top of the device.
Lift and remove the back cover.
Orient the device so the screen is facing the ground.
Using your finger, gently lift the top of the SIM card.
Using a T6 Torx Screwdriver, remove the four torx screws located on the bottom half of the device.
Orient the device so that the screen is facing you.
Using a spudger, remove the ear piece cover.
Using a T6 Torx Screwdriver, remove the two torx screws located in the top corners of the device.
Orient the device so the screen is facing the ground and the top of phone is facing you.
Using a pair of tweezers, lift and remove the following:
The two round connectors on the top of the mother board.
The flat connector in the lower corner of the mother board.
Ein weiterer Nutzer hat diese Anleitung absolviert.
