Zum Hauptinhalt wechseln
Blackberry Bold 9900 Back Case Replacement
Was du brauchst
  1. Blackberry Bold 9900 Back Case Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Back Case Replacement: Schritt 2, Bild 1 von 1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Back Case Replacement, Mini-SIM removal: Schritt 3, Bild 1 von 1
    • The Mini-SIM card is located inside the red rectangle.
    • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
  4. Blackberry Bold 9900 Back Case Replacement, MicroSD card: Schritt 4, Bild 1 von 2 Blackberry Bold 9900 Back Case Replacement, MicroSD card: Schritt 4, Bild 2 von 2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  5. Blackberry Bold 9900 Back Case Replacement, Keyboard: Schritt 5, Bild 1 von 2 Blackberry Bold 9900 Back Case Replacement, Keyboard: Schritt 5, Bild 2 von 2
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  6. Blackberry Bold 9900 Back Case Replacement: Schritt 6, Bild 1 von 2 Blackberry Bold 9900 Back Case Replacement: Schritt 6, Bild 2 von 2
    • Remove the two exposed screws using the T5 Torx screwdriver.
  7. Blackberry Bold 9900 Back Case Replacement: Schritt 7, Bild 1 von 1
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  8. Blackberry Bold 9900 Back Case Replacement: Schritt 8, Bild 1 von 2 Blackberry Bold 9900 Back Case Replacement: Schritt 8, Bild 2 von 2
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
  9. Blackberry Bold 9900 Back Case Replacement, Back Case: Schritt 9, Bild 1 von 1
    • Using the T5 Torx Screwdriver, remove the four torx screws that are located on the bottom half of the device
  10. Blackberry Bold 9900 Back Case Replacement: Schritt 10, Bild 1 von 1
    • Now, carefully and gently using your fingers, lift and remove the assembly from the back case.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Sowmika
253 Reputation
2 Anleitungen geschrieben
Baylor, Team S1-G4, Johnson Spring 2018 Mitglied von Baylor, Team S1-G4, Johnson Spring 2018
BU-JOHNSON-S18S1G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 16
Insgesamt: 1,436
