Zum Hauptinhalt wechseln
Blackberry Bold 9900 Trackpad Replacement
Was du brauchst
  1. Blackberry Bold 9900 Trackpad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Trackpad Replacement: Schritt 2, Bild 1 von 1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Trackpad Replacement, MicroSD card: Schritt 3, Bild 1 von 2 Blackberry Bold 9900 Trackpad Replacement, MicroSD card: Schritt 3, Bild 2 von 2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  4. Blackberry Bold 9900 Trackpad Replacement, Keyboard: Schritt 4, Bild 1 von 2 Blackberry Bold 9900 Trackpad Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  5. Blackberry Bold 9900 Trackpad Replacement: Schritt 5, Bild 1 von 2 Blackberry Bold 9900 Trackpad Replacement: Schritt 5, Bild 2 von 2
    • Remove the two exposed screws using the T5 Torx screwdriver.
  6. Blackberry Bold 9900 Trackpad Replacement: Schritt 6, Bild 1 von 1
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  7. Blackberry Bold 9900 Trackpad Replacement: Schritt 7, Bild 1 von 2 Blackberry Bold 9900 Trackpad Replacement: Schritt 7, Bild 2 von 2
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
  8. Blackberry Bold 9900 Trackpad Replacement, Trackpad: Schritt 8, Bild 1 von 3 Blackberry Bold 9900 Trackpad Replacement, Trackpad: Schritt 8, Bild 2 von 3 Blackberry Bold 9900 Trackpad Replacement, Trackpad: Schritt 8, Bild 3 von 3
    • Push into the trackpad. This will release the trackpad supporting piece.
  9. Blackberry Bold 9900 Trackpad Replacement: Schritt 9, Bild 1 von 2 Blackberry Bold 9900 Trackpad Replacement: Schritt 9, Bild 2 von 2
    • The trackpad is attached via ribbon cable. Pull this cable up in order to release the trackpad.
Abschluss
Baylor, Team S1-G4, Johnson Spring 2018 Mitglied von Baylor, Team S1-G4, Johnson Spring 2018
BU-JOHNSON-S18S1G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 1,023
