Zum Hauptinhalt wechseln
Blackberry Curve 8310 Screen Housing Replacement
Was du brauchst
  1. Blackberry Curve 8310 Screen Housing Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. Blackberry Curve 8310 Screen Housing Replacement: Schritt 2, Bild 1 von 1
    • Pry from the top of the battery to pull it out.
  3. Blackberry Curve 8310 Screen Housing Replacement, Lens: Schritt 3, Bild 1 von 1
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. Blackberry Curve 8310 Screen Housing Replacement: Schritt 4, Bild 1 von 1
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. Blackberry Curve 8310 Screen Housing Replacement: Schritt 5, Bild 1 von 1
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. Blackberry Curve 8310 Screen Housing Replacement: Schritt 6, Bild 1 von 3 Blackberry Curve 8310 Screen Housing Replacement: Schritt 6, Bild 2 von 3 Blackberry Curve 8310 Screen Housing Replacement: Schritt 6, Bild 3 von 3
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
  7. Blackberry Curve 8310 Screen Housing Replacement, Keyboard: Schritt 7, Bild 1 von 1
    • Remove the keyboard.
  8. Blackberry Curve 8310 Screen Housing Replacement, Screen Housing: Schritt 8, Bild 1 von 1
    • Remove the four T6 Torx screws located on the corners of the keyboard frame.
  9. Blackberry Curve 8310 Screen Housing Replacement: Schritt 9, Bild 1 von 2 Blackberry Curve 8310 Screen Housing Replacement: Schritt 9, Bild 2 von 2
    • Now remove the left and right side panels.
  10. Blackberry Curve 8310 Screen Housing Replacement: Schritt 10, Bild 1 von 3 Blackberry Curve 8310 Screen Housing Replacement: Schritt 10, Bild 2 von 3 Blackberry Curve 8310 Screen Housing Replacement: Schritt 10, Bild 3 von 3
    • Remove the keyboard frame.
    • Be sure to unhook the screen housing from the motherboard before continuing. Refer to the square indicated in the second picture.
    • Now remove the screen housing.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Sean Willis
229 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 10-32, Amido Winter 2012 Mitglied von Cal Poly, Team 10-32, Amido Winter 2012
CPSU-AMIDO-W12S10G32
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 1,651
