Einleitung
This guide will show you how to:
- Remove the battery
- Remove the front panel
- Replace the keyboard
Was du brauchst
Use a plastic opening tool to gently pry the bottom cover loose.
Pull the cover from the front of the phone after the back is loose.
Gently pry off the side casings from the top.
You will not need to remove the sides on the bottom.
Use a plastic opening tool to detach the securing clips holding the the front panel in place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
