Zum Hauptinhalt wechseln
Blackberry Curve 8320 Keyboard Replacement
Was du brauchst
  1. Blackberry Curve 8320 Keyboard Replacement, Front Panel: Schritt 1, Bild 1 von 3 Blackberry Curve 8320 Keyboard Replacement, Front Panel: Schritt 1, Bild 2 von 3 Blackberry Curve 8320 Keyboard Replacement, Front Panel: Schritt 1, Bild 3 von 3
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  2. Blackberry Curve 8320 Keyboard Replacement: Schritt 2, Bild 1 von 2 Blackberry Curve 8320 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  3. Blackberry Curve 8320 Keyboard Replacement: Schritt 3, Bild 1 von 2 Blackberry Curve 8320 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  4. Blackberry Curve 8320 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  5. Blackberry Curve 8320 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
  6. Blackberry Curve 8320 Keyboard Replacement, Keyboard: Schritt 6, Bild 1 von 2 Blackberry Curve 8320 Keyboard Replacement, Keyboard: Schritt 6, Bild 2 von 2
    • Remove the keyboard.
    • Be careful not to bend or fold the keyboard, as it can break easily.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 3-6, Regan Fall 2011 Mitglied von Cal Poly, Team 3-6, Regan Fall 2011
CPSU-REGAN-F11S3G6
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 2,026
