Einleitung
This guide is designed to help consumers replace their Blackberry Curve 9300 keyboard.
Was du brauchst
Locate the indent on the bottom of the back cover.
Use your fingernail to lift and remove the back cover.
Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
