Einleitung
This guide was written to aid with Blackberry Curve screen replacement. Following the steps below should provide relatively simple means of achieving this goal.
  1. Place your Blackberry face down in front of you.
    • Place your Blackberry face down in front of you.
  2. Locate the indent on the bottom of the back cover.
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. From the top, use your fingernail to lift and remove the battery.
    • From the top, use your fingernail to lift and remove the battery.
  4. Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
    • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
  5. Place the phone face up and use tweezers to securely grip and lift the screen upwards. Place the phone face up and use tweezers to securely grip and lift the screen upwards.
    • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
  6. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  7. Use a plastic opening tool to lift the bottom edge of the front cover.
    • Use a plastic opening tool to lift the bottom edge of the front cover.
  8. Use your nails to unclip the sides of the frame from the phone.
    • Use your nails to unclip the sides of the frame from the phone.
  9. Lift and remove the frame.
    • Lift and remove the frame.
  10. Lift and remove the keyboard.
    • Lift and remove the keyboard.
  11. Locate and remove the two 5mm screws on top of keyboard base using the T6 Torx screwdriver
    • Locate and remove the two 5mm screws on top of keyboard base using the T6 Torx screwdriver
  12. Carefully pull the keyboard base up and away from the phone.
    • Carefully pull the keyboard base up and away from the phone.
    • Disconnect the keyboard base from the phone completely.
  13. Locate and remove the four 5mm screws on the top and bottom of the phone with a T6 Torx screwdriver Locate and remove the four 5mm screws on the top and bottom of the phone with a T6 Torx screwdriver Locate and remove the four 5mm screws on the top and bottom of the phone with a T6 Torx screwdriver
    • Locate and remove the four 5mm screws on the top and bottom of the phone with a T6 Torx screwdriver
  14. Use a plastic opening tool to find the crease below the screen. Insert where shown and use the tool to unclip the two sides of screen from body.
    • Use a plastic opening tool to find the crease below the screen.
    • Insert where shown and use the tool to unclip the two sides of screen from body.
    • The opening tool goes approximately midway between the top and bottom edge of the screen.
  15. From the back of the phone, use a finger to push the front piece of the phone away from the back piece. From the back of the phone, use a finger to push the front piece of the phone away from the back piece.
    • From the back of the phone, use a finger to push the front piece of the phone away from the back piece.
  16. Use a plastic opening tool to detach the ribbon cable from the top left corner of the screen, and separate the screen from the motherboard. Use a plastic opening tool to detach the ribbon cable from the top left corner of the screen, and separate the screen from the motherboard. Use a plastic opening tool to detach the ribbon cable from the top left corner of the screen, and separate the screen from the motherboard.
    • Use a plastic opening tool to detach the ribbon cable from the top left corner of the screen, and separate the screen from the motherboard.
Abschluss
8 weitere Nutzer haben diese Anleitung absolviert.
Alek Squires
416 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 14-7, Forte Fall 2013 Mitglied von Cal Poly, Team 14-7, Forte Fall 2013
CPSU-FORTE-F13S14G7
5 Mitglieder
5 Anleitungen geschrieben
would appreciate new ldc part # and order info! - - !
Donald Burgo - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 4,003
