Zum Hauptinhalt wechseln
Blackberry Curve 9300 Screen Replacement
Was du brauchst
  1. Blackberry Curve 9300 Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place your Blackberry face down in front of you.
  2. Blackberry Curve 9300 Screen Replacement: Schritt 2, Bild 1 von 1
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. Blackberry Curve 9300 Screen Replacement: Schritt 3, Bild 1 von 1
    • From the top, use your fingernail to lift and remove the battery.
  4. Blackberry Curve 9300 Screen Replacement, Keyboard: Schritt 4, Bild 1 von 1
    • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
  5. Blackberry Curve 9300 Screen Replacement: Schritt 5, Bild 1 von 2 Blackberry Curve 9300 Screen Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
  6. Blackberry Curve 9300 Screen Replacement: Schritt 6, Bild 1 von 1
    • Use a plastic opening tool to lift the bottom edge of the front cover.
  7. Blackberry Curve 9300 Screen Replacement: Schritt 7, Bild 1 von 1
    • Use your nails to unclip the sides of the frame from the phone.
  8. Blackberry Curve 9300 Screen Replacement: Schritt 8, Bild 1 von 1
    • Lift and remove the frame.
  9. Blackberry Curve 9300 Screen Replacement: Schritt 9, Bild 1 von 1
    • Lift and remove the keyboard.
  10. Blackberry Curve 9300 Screen Replacement, Screen: Schritt 10, Bild 1 von 1
    • Locate and remove the two 5mm screws on top of keyboard base using the T6 Torx screwdriver
  11. Blackberry Curve 9300 Screen Replacement: Schritt 11, Bild 1 von 1
    • Carefully pull the keyboard base up and away from the phone.
    • Disconnect the keyboard base from the phone completely.
  12. Blackberry Curve 9300 Screen Replacement: Schritt 12, Bild 1 von 3 Blackberry Curve 9300 Screen Replacement: Schritt 12, Bild 2 von 3 Blackberry Curve 9300 Screen Replacement: Schritt 12, Bild 3 von 3
    • Locate and remove the four 5mm screws on the top and bottom of the phone with a T6 Torx screwdriver
  13. Blackberry Curve 9300 Screen Replacement: Schritt 13, Bild 1 von 2 Blackberry Curve 9300 Screen Replacement: Schritt 13, Bild 2 von 2
    • Use a plastic opening tool to find the crease below the screen.
    • Insert where shown and use the tool to unclip the two sides of screen from body.
    • The opening tool goes approximately midway between the top and bottom edge of the screen.
  14. Blackberry Curve 9300 Screen Replacement: Schritt 14, Bild 1 von 2 Blackberry Curve 9300 Screen Replacement: Schritt 14, Bild 2 von 2
    • From the back of the phone, use a finger to push the front piece of the phone away from the back piece.
  15. Blackberry Curve 9300 Screen Replacement: Schritt 15, Bild 1 von 3 Blackberry Curve 9300 Screen Replacement: Schritt 15, Bild 2 von 3 Blackberry Curve 9300 Screen Replacement: Schritt 15, Bild 3 von 3
    • Use a plastic opening tool to detach the ribbon cable from the top left corner of the screen, and separate the screen from the motherboard.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Alek Squires
431 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 14-7, Forte Fall 2013 Mitglied von Cal Poly, Team 14-7, Forte Fall 2013
CPSU-FORTE-F13S14G7
5 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
would appreciate new ldc part # and order info! - - !
Donald Burgo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 4,733
