Zum Hauptinhalt wechseln
Blackberry Key 2 LE Keyboard Replacement
Was du brauchst
  1. Blackberry Key 2 LE Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 2 Blackberry Key 2 LE Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Turn off your device before starting.
    • Flip the phone over so that the back camera is facing you.
  2. Blackberry Key 2 LE Keyboard Replacement: Schritt 2, Bild 1 von 3 Blackberry Key 2 LE Keyboard Replacement: Schritt 2, Bild 2 von 3 Blackberry Key 2 LE Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Use a your hands to remove the backing of the phone.
    • Use your phillips screwdriver to begin removing all the accesible screws.
    • Now begin to remove the coverings above and below the middle plate with your hand.
    • use your hand or a tool to remove the tabbing on the metal plate covering the battery.
    • Remove the metal plate covering the battery.
    • Use your wedging tool to begin removeing the adhesive under the battery.
    • Remove these two screws with your phillips screw driver.
    • Open the two metal tabs
    • Flip the phone back over with the screen facing you.
    • Begin to use the wedging tool to remove the space bar off of the keyboard.
    • remove the screws on each end of the space bars vacant lcoation.
    • Grab the wedging tool and begin wedging the old keyboard.
    • begind wedging the back of the keyboard until free.
    • Begin deperating the keyboard from the backing.
    • grab your replacement keyboard and connect it to the backing of the old keyboard.
    • place the keyboard back onto the front of the phone
    • once placed, hold the keyboard onto the phone while clicking the two metal plates back down to connect the keyboard.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 23
Insgesamt: 1,335
