Zum Hauptinhalt wechseln
Blackberry RIM 7250 Back Housing Replacement
Was du brauchst
  1. Blackberry RIM 7250 Back Housing Replacement, Battery: Schritt 1, Bild 1 von 3 Blackberry RIM 7250 Back Housing Replacement, Battery: Schritt 1, Bild 2 von 3 Blackberry RIM 7250 Back Housing Replacement, Battery: Schritt 1, Bild 3 von 3
    • Push the release button down and away from the device.
    • Slide the cover off toward the bottom of the device, revealing the battery compartment.
  2. Blackberry RIM 7250 Back Housing Replacement: Schritt 2, Bild 1 von 3 Blackberry RIM 7250 Back Housing Replacement: Schritt 2, Bild 2 von 3 Blackberry RIM 7250 Back Housing Replacement: Schritt 2, Bild 3 von 3
    • Place your finger in the groove next to the battery.
    • Lift your finger up to eject the battery from the battery compartment.
  3. Blackberry RIM 7250 Back Housing Replacement: Schritt 3, Bild 1 von 3 Blackberry RIM 7250 Back Housing Replacement: Schritt 3, Bild 2 von 3 Blackberry RIM 7250 Back Housing Replacement: Schritt 3, Bild 3 von 3
    • Remove the battery from the compartment.
  4. Blackberry RIM 7250 Back Housing Replacement, Back Housing: Schritt 4, Bild 1 von 2 Blackberry RIM 7250 Back Housing Replacement, Back Housing: Schritt 4, Bild 2 von 2
    • Remove the four 10.7 mm Torx T6 screws.
  5. Blackberry RIM 7250 Back Housing Replacement: Schritt 5, Bild 1 von 2 Blackberry RIM 7250 Back Housing Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 5 mm Torx T6 screws.
  6. Blackberry RIM 7250 Back Housing Replacement: Schritt 6, Bild 1 von 1
    • Hold the phone with one hand, with the bottom facing toward you.
    • For both clips, insert the plastic opening tool and push away from you.
    • You will hear a clicking sound for each clip that is released.
  7. Blackberry RIM 7250 Back Housing Replacement: Schritt 7, Bild 1 von 3 Blackberry RIM 7250 Back Housing Replacement: Schritt 7, Bild 2 von 3 Blackberry RIM 7250 Back Housing Replacement: Schritt 7, Bild 3 von 3
    • Grab the back housing from the bottom and lift the housing away from you.
Abschluss
Noah Eckert
519 Reputation
5 Anleitungen geschrieben
IUPUI, Team S2-G4, Baechle Fall 2018 Mitglied von IUPUI, Team S2-G4, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G4
3 Mitglieder
Ein Kommentar
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 177
