Einleitung
This guide will be useful in replacing the back housing for the Blackberry RIM 7250. For this guide, you will need a plastic opening tool and a Torx #6 screwdriver head.
Was du brauchst
Push the release button down and away from the device.
Slide the cover off toward the bottom of the device, revealing the battery compartment.
Place your finger in the groove next to the battery.
Lift your finger up to eject the battery from the battery compartment.
Hold the phone with one hand, with the bottom facing toward you.
For both clips, insert the plastic opening tool and push away from you.
