Zum Hauptinhalt wechseln
Blackberry RIM 7250 Side Button Replacement
Was du brauchst
  1. Blackberry RIM 7250 Side Button Replacement, Battery: Schritt 1, Bild 1 von 3 Blackberry RIM 7250 Side Button Replacement, Battery: Schritt 1, Bild 2 von 3 Blackberry RIM 7250 Side Button Replacement, Battery: Schritt 1, Bild 3 von 3
    • Push the release button down and away from the device.
    • Slide the cover off toward the bottom of the device, revealing the battery compartment.
  2. Blackberry RIM 7250 Side Button Replacement: Schritt 2, Bild 1 von 3 Blackberry RIM 7250 Side Button Replacement: Schritt 2, Bild 2 von 3 Blackberry RIM 7250 Side Button Replacement: Schritt 2, Bild 3 von 3
    • Place your finger in the groove next to the battery.
    • Lift your finger up to eject the battery from the battery compartment.
  3. Blackberry RIM 7250 Side Button Replacement: Schritt 3, Bild 1 von 3 Blackberry RIM 7250 Side Button Replacement: Schritt 3, Bild 2 von 3 Blackberry RIM 7250 Side Button Replacement: Schritt 3, Bild 3 von 3
    • Remove the battery from the compartment.
  4. Blackberry RIM 7250 Side Button Replacement, Back Housing: Schritt 4, Bild 1 von 2 Blackberry RIM 7250 Side Button Replacement, Back Housing: Schritt 4, Bild 2 von 2
    • Remove the four 10.7 mm Torx T6 screws.
  5. Blackberry RIM 7250 Side Button Replacement: Schritt 5, Bild 1 von 2 Blackberry RIM 7250 Side Button Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 5 mm Torx T6 screws.
  6. Blackberry RIM 7250 Side Button Replacement: Schritt 6, Bild 1 von 1
    • Hold the phone with one hand, with the bottom facing toward you.
    • For both clips, insert the plastic opening tool and push away from you.
    • You will hear a clicking sound for each clip that is released.
  7. Blackberry RIM 7250 Side Button Replacement: Schritt 7, Bild 1 von 3 Blackberry RIM 7250 Side Button Replacement: Schritt 7, Bild 2 von 3 Blackberry RIM 7250 Side Button Replacement: Schritt 7, Bild 3 von 3
    • Grab the back housing from the bottom and lift the housing away from you.
  8. Blackberry RIM 7250 Side Button Replacement, Front Housing: Schritt 8, Bild 1 von 2 Blackberry RIM 7250 Side Button Replacement, Front Housing: Schritt 8, Bild 2 von 2
    • Place your thumb on the bottom rectangle and your index finger on the top rectangle.
    • Squeeze your fingers together to release the internals from the front housing.
  9. Blackberry RIM 7250 Side Button Replacement: Schritt 9, Bild 1 von 3 Blackberry RIM 7250 Side Button Replacement: Schritt 9, Bild 2 von 3 Blackberry RIM 7250 Side Button Replacement: Schritt 9, Bild 3 von 3
    • Pull the two pieces apart to separate the front housing from the internals.
  10. Blackberry RIM 7250 Side Button Replacement, Side Button: Schritt 10, Bild 1 von 2 Blackberry RIM 7250 Side Button Replacement, Side Button: Schritt 10, Bild 2 von 2
    • Remove the single 5 mm Torx T6 screw.
  11. Blackberry RIM 7250 Side Button Replacement: Schritt 11, Bild 1 von 3 Blackberry RIM 7250 Side Button Replacement: Schritt 11, Bild 2 von 3 Blackberry RIM 7250 Side Button Replacement: Schritt 11, Bild 3 von 3
    • Grab side button housing with your thumb and index finger.
    • Remove the side button housing from the internals.
  12. Blackberry RIM 7250 Side Button Replacement: Schritt 12, Bild 1 von 3 Blackberry RIM 7250 Side Button Replacement: Schritt 12, Bild 2 von 3 Blackberry RIM 7250 Side Button Replacement: Schritt 12, Bild 3 von 3
    • Hold the side button housing with one hand and hold the side button with the other.
    • Lift the side button from side button housing.
    • There will be a subtle click when the side button is detached from the side button housing.
Abschluss
Noah Eckert
519 Reputation
5 Anleitungen geschrieben
IUPUI, Team S2-G4, Baechle Fall 2018 Mitglied von IUPUI, Team S2-G4, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 137
