Einleitung
This guide will be useful in replacing the side button for the Blackberry RIM 7250. For this guide, you will need a plastic opening tool and a Torx #6 screwdriver head.
Was du brauchst
Push the release button down and away from the device.
Slide the cover off toward the bottom of the device, revealing the battery compartment.
Place your finger in the groove next to the battery.
Lift your finger up to eject the battery from the battery compartment.
Hold the phone with one hand, with the bottom facing toward you.
For both clips, insert the plastic opening tool and push away from you.
Place your thumb on the bottom rectangle and your index finger on the top rectangle.
Squeeze your fingers together to release the internals from the front housing.
Grab side button housing with your thumb and index finger.
Remove the side button housing from the internals.
Hold the side button housing with one hand and hold the side button with the other.
Lift the side button from side button housing.
