Was du brauchst
Remove front silver trim by using plastic opening tools and wiggle it off.
Once you remove the rim cover, you should find two more screws on the top. Unscrew them using the T6 screw driver.
Peel off the three ribbon cables
The cable circled in yellow is glued to the silver cap. Pull the ribbon cable upward towards the battery area.
Remove gold sticky film that attaches the digitizer to the screen
Separate the digitizer from its screen
Move the digitizer to remove both circled screws with a T-4 bit.
The screw in red is under the screen, be careful of the ribbon cable in the top left corner.
Use a plastic opening tool to separate the assembly.
This ribbon cable comes out with a simple tug.
Pull the digitizer off the face of the phone and carefully guiding the ribbon cable out of the slot.
3 weitere Personen haben diese Anleitung absolviert.
